LT 500 Pipe (Bills or FMF)
Old Feb 14, 2006 | 01:25 PM
ERBEDS650's Avatar
Default LT 500 Pipe (Bills or FMF)
LT 500 Pipe (Bills or FMF) Yes I know the LRD and the Paul Turner are great, but that what I have so which one is better??
Old Feb 14, 2006 | 02:59 PM
HobbitOnAZilla's Avatar
The Bills is going to give you a lot more bottom end. The FMF will give you better mid to top end. so it depends on your preference's and the type of rideing you like to do.
Old Feb 14, 2006 | 03:07 PM
ERBEDS650's Avatar
Glamis dunesssss, with the FMF do you have to use there Silencer or can you use yes I still have one an Answer Silencer.
Old Feb 14, 2006 | 04:46 PM
RK's Avatar
RK
Hi,
IMO you should try get a pipe that is designed to run w/the porting in the motor and the type of riding/powerband that you like.
But be careful w/a high compression Zilla motor....................... some pipes have a "restriction" where the stinger is welded on to the end of the pipe.
This can cause the piston to overheat/detonate at higher RPMs and you will seize the motor.
Always start rich w/your jetting and then slowly work back down.
There are other WAY better pipes than the Bills, FMF, LRD, PT..................... they are "generic"
pipes designed in the 80s...................... good, but not on par w/today's designs.
$.02
RK
Old Feb 14, 2006 | 04:51 PM
i'm not sure but i would think that you could use any silencer. because i have a paul turner pipe and i'm useing the fmf silencer. but before you buy the pipe i would check some mesurements.
Old Feb 14, 2006 | 05:07 PM
ERBEDS650's Avatar
Rk?
what pipes to you sugest?? ALso did you get my PM on jetting??
mrtidy
Feb 3, 2016 05:00 PM
shimanok2
Jan 29, 2016 07:37 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
Sep 10, 2015 01:56 AM
