Muffler for the King Quad
Old Feb 28, 2006 | 08:11 PM
UtahQuadsquad's Avatar
Default Muffler for the King Quad
I would like to put an aftermarket pipe on my KQ. I am not sure which one would be best for me. I do a lot of technical riding in the mountains, with some blasting at times. What would you all recommend? What have you done? Would you recommend a slip on or a full system? Thanks for your help.
Old Feb 28, 2006 | 08:48 PM
RedGoblin's Avatar
I don't think there is a full system available at all. That said, I would go with the Yoshimura. Check it out on Nyroc's and other forums. Nothing but good things said about it.
Old Feb 28, 2006 | 10:14 PM
LKGRenegade22's Avatar
Get the Yoshi. I have the HMF slip on and I am about the change to the Yoshi because ther power commander map for the HMF sucks and I have someone that is going to send me the perfect map for the yoshi because he had his dyno tuned. Right know with the HMF I keep having to change spark plugs because I am running so rich. I love the HMF for the sound but I was the proper A/F mixture and the power increase of the correct map. I have had some people complain about the noise level of the HMF but I liked it.
Old Feb 28, 2006 | 11:12 PM
DavAsh's Avatar
Very happy with the Yoshi pipe. Fit and finish are second to none. Sounds good without being tooloud. You can remove the tip and be stupid loud and amke a lot of the neighbors mad st you. lol
LGK,let me know when you want me to send the map for the power commander. If any one else wants it, I will need you to PM me with you email address. I cannot attack it to the forums PM systems.
RedGoblin, you are correct. You can only get a slip on for the king. No one has a full system for the king. I would like to see one made but I have been told that the stock header pipe is pretty ood on the King.
Thanks
David
slowgsxr97
Mar 18, 2022 03:40 AM
Frisky2050
Apr 9, 2020 11:19 AM
Ashley S
May 29, 2017 10:54 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
