Lt500R Balance Shaft
Old Mar 20, 2006 | 04:22 PM
MJM's Avatar
MJM
Default Lt500R Balance Shaft
My balance shaft in my lt500r has been broken since I bought it. I finally just broke down the motor thinking I had tranny problems than realizing that the nut that came off the balance shaft was getting in the way of my 1/2 shift. I though bolts were vibrating out cause of the long rod setup, but i think its cause there was no balance shaft.
My q's..
anyone have a used balance shaft?
anyone run without one intentionally?
other than vibration, anything bad happen if I remove it?
Looking for any info you may have.
thanks,
Mike
Old Mar 20, 2006 | 07:45 PM
gogoquadzilla's Avatar
i imagine you would have to tighten every bolt on the bike after you ride it every time. but more importantly isnt there a seal around that shaft that goes from the left side, all the way thru the gearbox to the right side? its only 100 bucks new. ronnies.com
Old Mar 20, 2006 | 11:28 PM
Duneaddict's Avatar
I've got a used one in good shape... PM me if you want... I can fix you up.
I wouldn't run one without it... Self destruction at its finest!
Old Mar 21, 2006 | 12:35 AM
donzilla's Avatar
i totally agree with dune . you can run it without it .... for a few minutes . then you will be replacing more then the balancer shaft .
Old Mar 21, 2006 | 09:58 AM
MJM's Avatar
MJM
How much do you want for it? I need the shaft, the nut and washer, and could use the gear if you have one kicking around.
Thanks for the advice.
Mike
Old Mar 22, 2006 | 01:26 AM
Duneaddict's Avatar
PM Sent.
I'm missing the nut and washer, but shaft comes with the gear.
thanks,
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
firsttimerider
Sep 20, 2015 09:07 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Canamaniac!
Sep 15, 2015 06:19 PM
