SPROCKET QUESTION
Old Mar 31, 2006 | 08:18 PM
mikesz400's Avatar
Default SPROCKET QUESTION
To reach a higher top end speed on my z400, which sprocket do I need to change and should I go up one tooth or go down 1 tooth for faster top end. Also when I do this will it make my lower gears doggy. (so to speak)
anything will help. thanks:[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 31, 2006 | 10:09 PM
Bastosako's Avatar
for more top end you go more in the front and less in the back i believe
Old Mar 31, 2006 | 10:59 PM
sahzookee's Avatar
yeah, for more speed go up in the front and down in the rear. You probably will not notice a significant change in your lower gears. Maybe a little but nothing to be alarmed about. You'll still be getting enough torque to get the job done. On my 230s the stock rear I believe is recommended to be 41 and I run a 39. I think the front is supposed to be a 12 or 13 and I run a 13 or 14 and I still go anywhere I choose too with no problem.
Old Mar 31, 2006 | 11:24 PM
mucky's Avatar
try here .gears
Old Apr 1, 2006 | 03:41 PM
mikesz400's Avatar
thanks for the help guys
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
wendal
Sep 15, 2015 01:50 PM
