pls help
Old Mar 31, 2006 | 11:53 PM
atv122's Avatar
Default pls help
im giting new rings how do i put them on my lt230s and how hard is it and do i need to retime it if so how thanks
Old Apr 1, 2006 | 10:49 AM
mucky's Avatar
Default pls help
im not up on the lt230 but installing a set of rings are easy to do. just make sure the end gaps are offset from each other and you
have the top of the rings facing up. If im thinking correctly the 230 is a 2 stroke and youwont have to worry about timing
if its a 4 stroke then you do
