95 300 King Quad lift kit
Hey Everyone!
Can Anyone tell me how I can get 2" of lift on my 95 300 King Quad?
I tried installing 4" spacers on the lower shock mounts, It gets it in the air but the back U Joints bottom out and the back tires pivot in like an old VW Bug! I am thinking about chanhing tires to 26" one the back and 25's on the front. Anyone have any experance with this?
Any help would be great!
Thanks
Thanks
I put 26/25 mudlites on mine. Works fine. best to use 2wd and only 4 when you need it because the gearing gradually loads up a bit but nothing serious.
Forget lifting the body, you'll only bust CV joints
since in 4wd the front and rear are geared together and the circumfrences of the tires are not the perfect proportion, the y develope a load on the respective gear faces when operated on hard surfaces. A certain amount of 'scratch' releives this on gravel but it's more efficient to just use 2WD unless 4wd is needed.
Frisky2050
Apr 9, 2020 11:19 AM
