Z400 axle nuts
Old May 17, 2006 | 10:41 AM
MR2xxx's Avatar
Default Z400 axle nuts
For removing the two large axle nuts, what size wrenches do I need? Also, any tips or tricks for removing and reinstalling the axle and bearings.
Old May 17, 2006 | 11:46 PM
mucky's Avatar
I used 2 pipe wrenches on mine with cheater bars. they are very tight. once you remove the nuts the axle just slides out once you have the brake caliper removed ,as for bearings once the axle is removed you need to remove the bearing carrier and then the bearings
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
