LT80 Aftermarket Pipe
Old May 18, 2006 | 08:04 PM
wildirishman's Avatar
Default LT80 Aftermarket Pipe
If I install an aftermarket pipe on a LT80 do I need to rejet orwill it be OK with the stock jets???? Anything else need done to it with the pipe? Thanks,Irish
Old Jun 29, 2006 | 12:13 PM
minikaleb's Avatar
yeah you do need to jet it it is easy im only 14 and i did it just take off the carb and then take off the bottom off the carb then take out the jet it is the small brass cyrcel on the stem in the middle just un screw it and get a drill bit small eenuff to fit in it then find the next size up and drill and put it back together or you could bore it out with a die grinder its delta shaped so it has to be done by hand try it ill garentee it and one more thing modify the air box by cutting the hole bigger it works
minikaleb
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
cboler9
Sep 24, 2015 08:35 PM
merryman
Sep 19, 2015 03:15 AM
greg86hd
Sep 16, 2015 12:32 AM
