03 suzuki z400 carb
it might not be a carb problem. the 03 had some problems with the fuel petcock plugging up a little. try cleaning it
and the 05 should work on the 03 you just dont need the TPS. and you might have to rejet it
Runs fine with the choke on but dies when I turn it off. Cleaned the carb 3 times and took out the needle and all the jets and cleaned all them. I havent tried the petcock but I am up for anything. Keep 'em comming guys thanks..!!
check the intake, it might have a leak run it at an idol enough to keep it running then spray carb cleaner or water in intake fittinngs if the motor changes sounds or dies, it is a leak,
go to my site for carb issues
it is my url at bottom of my post
cool if not bring it down
im in back of the laundry mat on main street
