1999 king quad starter problem HELP PLEASE
My King Quad cranks but won't turn over. I try ro start it, give a little gat and it turns over twice and than clicks away like the battery is going out.
Is it the starter, battary or something else? An how do I fix it. Suzuki 1999 King Quad 300 ATV
Thanks
Thanks
you need to do some more digging.
charge the battery,
check the postive and negative leads for good connections
make sure it's good fuel
good spark?
engines need fuel, air, spark and time.
charge the battery,
good spark?
I charged the battary twice. The second time it appears to have started OK It may be the battery on it's way out. At least i know it isn't the starter
Thanks for your help
Also check to make sure all of your wiring is ok. My Z250 was doing the same thing and the problem progressively became worse. It turned out my ground wire was loose and shorting everything out.
Bleach
1) Engine problems..
16
May 16, 2021 08:23 AM
DTroyer01
Jul 3, 2015 07:34 AM
