z400 swingarm adjustment bolt
Old Aug 6, 2006 | 01:14 PM
hapkido44's Avatar
Default z400 swingarm adjustment bolt
Hi
Had a problem where the adjustment bolt actually broke away from the axle carriier inside the swingarm...anyone else had this and is there an easy fix for this?..can u weld the piece back on?..looks like the whole axle will have to be removed to get this bolt back in place..sigh..any help or suggestions would be appreciated.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 7, 2006 | 03:35 PM
tallyloufsu's Avatar
Check with the guys at z400centrol and see what info you can find out there. Its happen to some people over there, but do a search first.
Old Aug 11, 2006 | 05:06 PM
witti's Avatar
I had this happen to me.
I pulled the other nut off. Then the plate will come off that goes around the bolts, this will give you plenty of room. I bought a new stud from the dealer. I drilled a small hole in the broken stud and used an easy out to remove it. Installed the new one and reassembled. Mine was broke off flush, you might be able to grab yours with a vise grip. The hardest part was centering the drill bit on the stud. I used a small socket to help me line it up.
From what I read I found it was caused by improper torque of the carrier clamping bolts. I now torque the carrier clamping bolts to spec each time I adjust the chain. The bolt with athe 17mm head is ~72 ft lbs, and the bolt with a 14mm head is ~53 ft lbs.
Also make sure your swingarm housing around your carrier is clean each time you adjust your chain.
Old Aug 11, 2006 | 09:38 PM
woodsracertofast's Avatar
hapkido44
about 2 weeks ago one of the 4 bolts u loosen to tighten the chain came out and i lost it,got that fixed last week end, i rode 2 days this week about 30 min or so after school and today i went to get ready to tighten my chain and mine done the exact same thing, i think were talkin about the same bolt(the one in the back to tighten the chain) broke. it wasnt even tighten all the way up it was about a forth of the way and the 3 of the 4 bolts u loosen to adjust the chain was loose after i put lock tight on the the first time it broke. mines a 06 and already falling apart.
Old Aug 12, 2006 | 01:51 AM
Channy's Avatar
THANKS 4 THE INFO!!!!!! I have been having trouble with the adjustments for awhile! I am glad to finally know what we can do about it!! (I kept breaking bolts!!!!!) I was starting to think it was my fault!!!!! Thanks for helping a girl out!!!!!
Old Aug 14, 2006 | 08:24 AM
hapkido44's Avatar
Hi
Well sounds like you guys have had simialar problems ..but with one difference...my bolt didnt break it broke right out of the axle carrier with a big chunk of aluminum,got it all ripped apart and a new axle carrier on order..[img]i/expressions/face-icon-small-sad.gif[/img]
Old Oct 13, 2010 | 09:03 PM
kapnobatai's Avatar
hey everyone. I'm new on here I ride a 03 z400 just got done putting the chain back on but i try to loosen the four bolts on top of the bearing carrier - swing arm and I could not get any of the long bolts to come out. I just loosen them up and the bottom 17mm on left was too tight even hit it with and impact gun try to loosen it up and nothing, I was afraid it was going to break it but, didn't but one of the 14mm on top right broke i guess over torqued it and broke! i got everything back on working fine but i only have 3 top bolts out of 4 any ideas on how i could replace the 14mm bolt?
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
GirlsCan2
Technical and How-To Articles
Aug 27, 2015 02:58 PM
MNatv89
Aug 12, 2015 06:00 PM
95wolv
Jul 21, 2015 12:25 PM
Jul 15, 2015 02:07 AM
