eiger tapping 06
Old Aug 11, 2006 | 11:48 PM
1statv's Avatar
Default eiger tapping 06
i bought this thing (eiger 400) brand new and ever since i've had it it makes a slight tapping from the motor after in warms up. What is it ? vaulve? muffuler? normal engine noise? Has this happened to anyone else? Did i make a mistake in buy this machine? I'm taking it to the shop for "piece of mind" but I would like some insite before going.
thanks
Old Aug 12, 2006 | 12:16 AM
g1387's Avatar
The engine noise is normal, it sounds like it's knocking a little bit but it's fine, you might also hear a winding noise from the tranny that is also normal. Don't let any of that bother you, this is an awesome machine, I have an 05, put it through hell and it still goes.
Old Aug 12, 2006 | 01:51 AM
bombrider04's Avatar
I don't have one but if its normal its normal I am curious on what type of gas you are using becuase it may be causing a valve tap
Old Aug 12, 2006 | 01:45 PM
1statv's Avatar
regular 87 octane from the corner store.Do i need to run premium?
Old Aug 12, 2006 | 07:08 PM
what does the manual say becuase I have to run premium in my ds it may help out alittle not sure but it sounds like a valve tap give it a try and see I don't have an eiger but its wortha a try or maybe it could have been bad gas
how long have you been riding it because after you break it in you should get the valves adjusted oil and spark plugs
Old Aug 12, 2006 | 09:46 PM
1statv's Avatar
manual calls for 83 or better only has 35 miles about 6 hrs
Old Aug 13, 2006 | 01:05 AM
alright just checking well if they say its normal maybe it is if there are any problems in the future give a shout
Old Aug 13, 2006 | 10:46 AM
Hollywood330's Avatar
............I just turned 3000 miles on my 2003 Eiger........stop worrying. A bit of engine noise is not unusual........especially with Suzuki.
Do the recommended break-in service..........the dealer will do a valve, LOF and send you on your way.
I'd suggest a service plan.......and use it.
Go to a pure synthetic oil........consider a K&N air filter (maintain it)
You have an excellent quad..........and don't pay too much attention to the cc junkies........you'll go everywhere they go........every time..........and for a long time.
Old Aug 13, 2006 | 01:11 PM
rolsmojave3's Avatar
Valve tap isn't caused by the wrong octane...Knocking is caused by low octane. Valve noise is from them being out of specs. The noise I belive he is hearing is from the cam chain. Z's do it also so I'm guessing it's a Suzuki thing
