IM CONFUSED
Old Aug 22, 2006 | 09:22 PM
redneckfromnb's Avatar
Default IM CONFUSED
hey guys,i got a 1986 quadrunner 250.i cant tell if its charging or not,the meter says 12 volts even reving it up.it will run without the battery.how can i tell if it is charging and if not why.where do i start looking?
thanks guys,your the pros
Old Aug 22, 2006 | 10:12 PM
mucky's Avatar
Default IM CONFUSED
if it runs without the battery then its charging,it may not be charging enough for what the bike should have and if it wasnt it would die
Old Aug 22, 2006 | 10:38 PM
Default IM CONFUSED
i dont know but you can start the bike with the satarter and some times the starter seems to drag,ive tried 3 starters they all do the same
Old Aug 22, 2006 | 11:11 PM
mucky's Avatar
Default IM CONFUSED
you might just have a weak battery or bad cables
Old Aug 23, 2006 | 08:03 PM
400fnSport's Avatar
Default IM CONFUSED
You should have anywhere between 13v and 14.5v when the engine is running. If you have 12.6v which is most a good battery will have, (2.1v per cell) then your not charging. Check your voltage coming out of your voltage regulator. It should be about 14 to 16 when revved. If not chances are that's your problem. Although it could possibly be your stator also. You will need to look in a manual and do a resistance check to make sure there isn't a open or short in your charging coils.
And like mucky said, make sure its not a weak or bad battery. I've had one battery in my day that would actually pull a load when attempted to be charged. It was on a streetbike that I replaced all charging components on, and come to find out it was the battery all along. Lessoned learned.
Old Aug 23, 2006 | 09:44 PM
Default IM CONFUSED
thanks guys ill try that
akguy31
Aug 31, 2019 04:34 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Pissed off
Sep 21, 2015 02:33 PM
Halffast17
Sep 11, 2015 02:30 PM
Jason Campbell
Sep 7, 2015 02:25 PM
