need help
Old Sep 24, 2006 | 10:50 AM
scottymac's Avatar
Default need help
i have a 1986 suzuki lt250f that i cant get started, it will turn over but i cant get it started. dont really know were i need to start on it. if someone could help i would greatly appreciate it. thanks in advance
Old Sep 24, 2006 | 11:04 AM
z400rider18's Avatar
Default need help
dose it have gas in it??? clean the spark plug try the choke if u havent
Old Sep 24, 2006 | 12:18 PM
benzzyo5's Avatar
Default need help
if u tried that just squirt some starting fluid in ther and it will start i had a 89 suzuki quadrunner and i havent startted it in 2 years i sprayed some starter fluid in one pull it fired up, at the time my battery was dead
Old Sep 24, 2006 | 11:24 PM
RappinErnie's Avatar
Default need help
If you've tried all that then make sure the gas lines arent pinched, and make sure the gas valve is opened.
