oil changes
Old Oct 4, 2006 | 09:04 PM
redneckfromnb's Avatar
Default oil changes
hi i got a 1986 quadrunner,i was wondering what type of oil filter it takes.ive never done the filter before.also how do i check to see if the bike is charging,it ill run without the battery in it.
thanks
Old Oct 8, 2006 | 09:09 PM
benzzyo5's Avatar
Default oil changes
mine takes 10w-40 and it's a '89. just ride it around and see if the ights get brighter, i don't know, or u can just leave the lights on all night then jump it in the morning and see if it charges, but the only thing is it might not get charged all the way and ruin your battery
Old Oct 29, 2006 | 11:03 AM
kenora's Avatar
Default oil changes
10W40 for summer, 5W30 for winter....gotta be motorcycle oil though NOT car oil...its different.....
and get a volt meter, set it on DC volts on the 20 volt scale...before you start the bike check the voltage between the + and - posts should be about 12.5ish vDC....start the bike, should be about 14ish vDC..if it doesn't change then your not charging...if it over about 14.5 vDC then you are overcharging and cooking the battery..
