'85 Quadsport Swingarm Bearings
Old Oct 16, 2006 | 08:27 PM
demo77's Avatar
Default '85 Quadsport Swingarm Bearings
My swingarm had a lot of play in it so I finally decided to take it apart. When I pulled the spacers out the needle bearings fell out, all in little, rusted, broken pieces. Now the bearing housings are in the swingarm and won't budge. I tried sawing through them but I don't want to go to far and saw through the swingarm. How do I get them out? Any advice is appreciated.
Thanks
Old Oct 17, 2006 | 04:53 PM
anotharida's Avatar
alot of pvc blaster should do and luck i guess
Old Oct 18, 2006 | 01:42 PM
bombrider04's Avatar
If you can try heading them and pulling them out or if you use a die grinder and cut it that way try lubing it up with wd40 first and let it sit them either push with tubing if you can or use an air gun if not heat them up and try it then or cut them.
Old Oct 18, 2006 | 07:49 PM
demo77's Avatar
I tried cutting through them but I need some new blades, hammering them out is way to hard, they don't budge. I'll try a torch, as a last resort.
Old Oct 18, 2006 | 08:18 PM
Alright let us know how you make out
Old Oct 18, 2006 | 10:24 PM
dropride's Avatar
I just changed mine today. Mine were really rusted as well , i ended up using a long punch and hammer to get them out.
Old Oct 19, 2006 | 06:58 PM
demo77's Avatar
What exactly did you use, I tried hammering them and the puch slides out, and skips of the edge. There isn't much left to the bearings, just the housings so I don't have much to hit off of. I'll try to get pictures.
Old Oct 19, 2006 | 09:54 PM
demo77's Avatar
I just finished another failed attempt of hammering them out. I ended up breaking off the lip, and all that remains is a tube inside the swingarm.
Picture 1
Picture 2
Picture 3
Old Oct 19, 2006 | 10:24 PM
dropride's Avatar
Only thing i could suggest is if you have torches you could put a slice in them to get it out or find someone good with torches to do it if your not comfortable with it. Any auto repair shop should be able to do it.
exmotocrosser
Sep 13, 2019 06:12 AM
fd24
Jan 16, 2019 08:59 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
jbrewster94
Sep 23, 2015 04:16 PM
