98 king quad 300 starting problems
Old Jan 28, 2007 | 11:48 PM
afilgo's Avatar
Default 98 king quad 300 starting problems
My brother has a kq 300 and has problems with cold starting. It will not crank with the starter, but will start with the pull start. Once it starts the first time it is good to go, but if it sits for a while it has a hard time starting again. Any suggestions?
Thanks
Old Jan 29, 2007 | 01:31 AM
Glenlivet's Avatar
Tired battery. Is it cold where you are these days? Try hooking a battery charger up and starting it cold, with the charger on there. If it fires up then there you go. The voltage drop from the starter draw is too much to leave enough for the ignition. What oil you got in there? Anything with more than a 5 in front (as in '10-30') for winter cold is too heavy in any case. Put in 0-30 or 0-40 Motorcycle oil and I bet it starts. Or maybe it's not that cold in Alabama.
Or get a new battery. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 29, 2007 | 01:18 PM
afilgo's Avatar
That is close to what he thinks it is. It has a new battery, but he thought it could be the rectifier. I think it has something to do with the carb or fuel delivery. Any other suggestions.
Old Jan 29, 2007 | 02:35 PM
hondabuster's Avatar
Its real doubtful that the rectifier is the problem. Have the battery load tested, its the only real confirmation of whether or not its good, age doesnt mean anything. Ive sen new batteries which were bad.
If the battery checks good, try the starter next. It could be rusty or packed with mud, or the resistance has changed due to wear on the brushes.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
ferret3
Aug 4, 1999 08:23 PM
