lt 250r electrical problem
Old Feb 18, 2007 | 05:37 PM
WaWa's Avatar
Default lt 250r electrical problem
I'm having problems with the electrical system on my 88 quadracer. It has been hard to start for the past year and now finally it won't start. Just before it died, I had to tow start it because I couldn't get it running. It would give me a loud backfire after kicking on it for 20 minutes and that's it. When I finally got it running it ran terrible, it wouldn't rev up and hardly run at all. I parked it and decided to change the plug, coil and cdi box since the spark seemed to be orange, not blue. I still have a weak to non existant spark. I can hold onto the black/red wire coming from the stator and kick it over and only feel a very, very weak spark. If it was a good stator I should have been knocked on my back right?
If anyone has had similar problems I would love to know how you fixed it. Ricky Stator has a stator for around $150. Should I change the stator or I am I over looking something?
Thanks
Old Feb 19, 2007 | 04:22 AM
1987LT250's Avatar
Do you have a manual if so you can check your electrical components without buying a stator and guessing.If not let me know ill give ya a link showing ya how, gl shon, i would also check the little banana keyway on the crank when you have the flywheel off make sure its not sheered . Im assuming you have good compression?
Old Feb 19, 2007 | 01:45 PM
WaWa's Avatar
Thanks for replying, any help I can get is greatly appreciated! I'm awful at electrical stuff.
I just pulled the flywheel off and the banana key was sheared! I also noticed that I am missing my lighting coils. Is there a way to check to make sure my yellow ignition coil and pulser are ok? If you could send me the link you mentioned, that would be great.
I rebuilt the top end recently and have plenty of compression. Do you know where I can find a banana key?
Thanks again
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Unzzy66
Jul 11, 2015 10:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
ranvette
Jul 4, 2015 06:13 PM
