z400 air filter & jetting?
Old Mar 18, 2007 | 01:06 AM
GoldHEMI's Avatar
Default z400 air filter & jetting?
The stock air filter just doesn't appear to make good seal to the box. I'm thinking of replacing it with the pro design adapter and uni filter.
If my quad is all stock and I just replace the filter will I have to rejet?
Thanks.
Old Mar 18, 2007 | 09:20 AM
cataway's Avatar
if you leave the air box lid on and the stock spark arrester in , no.
but why would you do that?
Old Mar 20, 2007 | 04:12 PM
scottphillips88's Avatar
I've got sort of the same question. I put a K&N on my KFX and removed the spark arrestor. It rides just fine now, but if I take the air box lid off it bogs down way bad when I hit the gas. Should I take the cover off and have it re-jetted?? Will there be a power difference with it off?
Old Mar 20, 2007 | 04:20 PM
cataway's Avatar
if you remove the lid and the spark arrester ,yes you Will have to rejet, a 142.5 small main is most likely the jet you will need .
this jetting is for under 3000 ft.
yes it will give you more power
NewGuy2481
Oct 6, 2015 05:54 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
1ArmBandit
Sep 8, 2015 08:59 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
