Lt250r decided to die
Old Apr 8, 2007 | 04:06 AM
anomaly's Avatar
Default Lt250r decided to die
I took out my 86 LT250r for a ride the other day and after riding it for about 10 minutes, suddenly it had no bottom end, and definitely wasnt pulling like it should, and had a surging idle. Also was producing more smoke than usual... just as i got back it stalled and hasnt started since. Could it be that i sheared the flywheel key that keeps the right timing? Or damaged a reed? Any ideas?
Thanks
Old Apr 16, 2007 | 07:58 PM
BrianCMiller's Avatar
It sounds like a seal went and it has an air leak (explains the surging idle) and gear oil is getting in the combustion chamber (explains the extra smoke). Check the cylinder base gasket and pray it is not the main bottom end seal between the halves.
-B
Levi Enstad
Sep 26, 2015 08:00 AM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Rick Van Matre
Sep 11, 2015 11:52 PM
Halffast17
Sep 11, 2015 02:30 PM
