how can i get a deeper sound what should i do
just take the whole exhuast off you don't need it and after a while since you don't have backpressure your valves and engine will be shot lol j/p...I would look for a slip on and you will hear a difference and also get yourself an airfilter...Try looking at hmf, yoshi, or procircuit...Make sure your rejet the quad with these mods though.
Well depending on what mods you decide to do will determine the jet size you will need to go with...You will need a new needle, main jet, and maybe a pilot depending on the mods...Once you have the quad jetted you will need to tune the quad by the adjuster at the bottom of the quad and after riding it for a little bit you will want to check the color of your spark plugs and make sure they aren't white (lean condition) and you will be looking for a tannish color which means it is good and a black plug means a rich condition.
Customer Service #1
May 15, 2020 08:46 AM
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
