z400 engine ticking
Old Apr 25, 2007 | 06:21 PM
Pepin's Avatar
Default z400 engine ticking
so i have an 06 z400, which i just put hotcams intake and exhaust cams in. when its running, there seems to be a ticking noise in the engine. it seems to be the cam chain, and i am wondering if it is the cam chain tensioner. The adjusting bolt is tight, but i was wondering if it would even make a difference how tight i have the bolt since there is a spring that automatically adjusts the tension when the chain stretches. could there be any other problem that i am unaware about? any help would be appreciated
Old Apr 27, 2007 | 01:42 AM
holtzer1's Avatar
did you install a new cam chain? its a good rule of thumb, no matter how many hours on the bike, when installing cams, install a new chain also. your valves could also be out of adjustment causing the ticking noise.
Old Apr 27, 2007 | 02:12 AM
LT250RSuperstar's Avatar
Yeah when you put in the cams, you should always double check your valve clearances. It could be the timing chain, but you have an '06. The timing chains on these machines are notorious for stretching.
Old Apr 27, 2007 | 08:14 AM
Pepin's Avatar
i checked the valve lash in all valves, and changed the shims so they were in manufactures specs, then did the recommended 30 min break in period. i noticed the ticking noise right off but kept breaking it in. i then tore it back apart, and rechecked valve clearances and all were still good. i put it all back together and there was still a noise, so i starting to think it might be the cam chain.
Old Apr 30, 2007 | 07:33 PM
LTZGUY's Avatar
Yup its ther cam chain. I did the same thing. Then put a new DID chain in....no noise anymore.
Old Apr 30, 2007 | 07:43 PM
kawiking's Avatar
cam chain... my atv repair shop guy use to race a z 440 so he knows his stuff. he took my cam chain tentioner spring and cut about half a inch off(after i put a new cam chain in). sorry but i forgot why he did it.
Old Apr 30, 2007 | 08:00 PM
LTZGUY's Avatar
HMMM...thats a good idea...bet it does not stretch the chain as fast......I might try that.....hmmmmm...thats a good one. Less drag too=more power.
Old May 6, 2007 | 11:40 PM
epic's Avatar
I hear the ticking noise also it drives me crazy i checked the cams they are perfect replaced the timing chain and am still hearing the noise
Old May 7, 2007 | 01:00 AM
LTZGUY's Avatar
what kind of chain you use?
Old May 7, 2007 | 10:31 AM
epic's Avatar
DID
