z400 jetting
Old Apr 25, 2007 | 06:40 PM
Pepin's Avatar
Default z400 jetting
on my z, i have a k&n/pro flow air intake kit, with the lid off, and a white bros e2 slip on. white bros suggests i use a 165 main jet with the lid off. should the jetting be different with the increased airflow of the k&n, or should i go with the 165. i ride about 2500 ft elevation, and want to buy just one jet instead of a set of jets for around 70 bucks.
Old Apr 25, 2007 | 06:45 PM
ZButcheR's Avatar
[quote]
Originally posted by: Pepin
on my z, i have a k&n/pro flow air intake kit, with the lid off, and a white bros e2 slip on. white bros suggests i use a 165 main jet with the lid off. should the jetting be different with the increased airflow of the k&n, or should i go with the 165. i ride about 2500 ft elevation, and want to buy just one jet instead of a set of jets for around 70 bucks.[/]
I run a 155 main,25 Pilot with about the same mods that you posted in the other thread...
Old Apr 25, 2007 | 10:00 PM
cataway's Avatar
the reason you need to rejet is because you have a free flowing pipe and because you have removed the air box lid . the stock filter will work but it is a piece of crap replacing it is a very good idea .
last summer i was using a Mikuni 165 , since my mods I've bumped it up a bit. if you look you will find a lot of guys using a 165.
the very best thing you could do is get your quad on a dyno and do a AF check .you could be running lean and never know it .
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
