cooling fan not working
Old Jul 8, 2007 | 09:36 PM
maximus817's Avatar
Default cooling fan not working
I have a 2007 Eiger 400 4x4 Semi-Auto its got about 40 miles on it, not more then 2 weeks old out of the crate. I was riding today and noticed my cooling fan was not comming on. I thought maybe it wasnt getting hot enough due to the fact I had been going through water that was kinda deep.(up to the seat) So i set and let it idle for about 10 minutes and it still didnt come on. So i took it back to my truck which was about a mile away and it still didnt come on thats when i figured something is wrong. Anybody got any ideas about the eiger fan? The last time I rode it a few days ago it was working . Thanks for any help guys later.
Old Jul 9, 2007 | 11:02 AM
Turkeyboy's Avatar
theres a 10 amp fuse under the seat check that i have a 05 and mine rarely ever comes on might not be nothing wrong
Old Jul 9, 2007 | 08:38 PM
maximus817's Avatar
mine has been comming on pretty regular since i got it but i will check that fuse thanks.
Old Jul 9, 2007 | 08:59 PM
maximus817's Avatar
well i checked all the fuses and they are all good. There is a clear rubber tube that comes from the fan and goes back by the seat is it suppose to hook to something or just hang there. It looks like a drain hose.
The fan was coming on pretty normal considering its hot out it would come on about every 5 or 10 minutes stay on for about a minute and then shut off.
Old Jul 11, 2007 | 02:05 PM
Krychezk's Avatar
I have an 06' Eiger and my fan just quit working too. I haven't figured out why yet, but i'm thinking it might be the relay. I'm probably going to change it soon so I will let you know if it works after that, I hoping its just the relay and not the fan(pretty big price difference)
Old Jul 11, 2007 | 07:31 PM
maximus817's Avatar
you didnt by chance take it through about 3 feet of water before it quit working did you. Because im thinking thats what got mine. do you know if the fan is water proof?
Old Jul 11, 2007 | 07:45 PM
Back40's Avatar
Check the cooling fan switch and make sure both wires are still connected. Squirrels chewed thru mine and I didn't realize it until the engine overheated light came on.
Old Jul 12, 2007 | 02:59 PM
Krychezk's Avatar
I did go through pretty deep water with mine the same weekend that it quit working, but I would think the fan would be sealed so that you can go through water.
Old Jul 13, 2007 | 05:47 PM
JacL's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Krychezk
I did go through pretty deep water with mine the same weekend that it quit working, but I would think the fan would be sealed so that you can go through water.</end quote></div>
Sometimes when you hit real deep water with the fan running it blows a fuse.
As for sealed, my 03 Vinson fan spends more time under water than above and still works.
Old Jul 13, 2007 | 11:00 PM
maximus817's Avatar
only fuses i saw were under the seat and there was 8 of them all good
