help me please!!!
Old Jul 26, 2007 | 07:05 PM
drunken_smurf's Avatar
Default help me please!!!
ok i was riding my 2003 ltz 400 today and it just died
now it will not start
will someone give me some ideas that may went wrong
the valves were loose could that have had anything to do with it
please help me
chris
Old Jul 26, 2007 | 10:49 PM
mucky's Avatar
are you getting fuel? spark? it might have jumped time if the timing chain get to loose. bad spark plug? CDI malfunction?blown fuse?
Old Jul 27, 2007 | 03:40 PM
i dont know
all i know is i was in a wheelie in third gear and it backfires bout 3 times and dies
then i tryed starting it and the motor wouldnt turn over
Old Jul 27, 2007 | 03:55 PM
emeraldisleatv's Avatar
What you mean valves were loose? Is it a overhead cam?
Old Jul 27, 2007 | 04:59 PM
the cliccking in the motor was caused by the loose valves
and i didnt get around to fixing them
could the valves caused any of this or would it be somthing else
and its a new spark plug and the carb was recently cleaned
Old Jul 27, 2007 | 05:18 PM
Well if the valves arent seating yes of course (I have been there with mx'ers). I would check the clearences, they will have gone to zero clearence if the seats are shot.
Old Jul 27, 2007 | 05:19 PM
You said about the motor not turning over? Is it locked up?
Old Jul 27, 2007 | 05:57 PM
well it sounds like it wants to start but it wont
and the motor is not locked up
but my mechanic said i needed to tighten the valves
but he pulled his arm and we didnt get to do it
im just getting opinions on what possibly could have went wrong before we go and take the motor apart and its something simple
Old Jul 27, 2007 | 06:20 PM
I persume its an over head cam. If it is over time the valves tighten, not loosen (this is mx'ers anyway) You will have to shim them. But I would say seen as its an 03 I can only persume it has a good few hours on it. A valve job would do no harm. Do you have a manual? Cheack the clearencs, it is very simple to do and it will tell you if you need shimming or not.
Old Jul 27, 2007 | 06:34 PM
yep 2003 ltz 400 5 speed
i will reply back when i get around to taking it apart probally sometime next week or so
thank you for helping me
