ltz400 overheating, fan not working
Old Sep 5, 2007 | 01:28 AM
Snowprincess's Avatar
Default ltz400 overheating, fan not working
i crashed and the handle bars went way down by the seat, i got them bent back up. same day i took it in three feet of mud and it died and was floating and i had to get pulled out. but then i noticed the fan wasnt working after i got it running again, any ideas why it doesnt run?
Old Sep 5, 2007 | 06:43 PM
DVXDUDE's Avatar
rad is likely so full of mud and maybe the wiring on the fan shorted out.
Old Sep 5, 2007 | 07:35 PM
powerstroke01's Avatar
It doesnt love you anymore. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Sep 5, 2007 | 09:04 PM
dont be silly, its just a little sick and needs some tlc..
Old Sep 6, 2007 | 12:45 AM
CWO4GUNNER's Avatar
get it very clean (pressure wash) let it dry out in the sun and get the shop manual and your multimeter out to do power checks to the fan motor and relay as you probubly have a short, blown fan fuse, or burned out fan motor. There is no guess work here you have to do the elec diagnostic checks and whether or not the fan is working and why is probubly one of the easiest. Otherwise you have to take it to the shop and the international rule for electrical problems is $100 minimum and $100 per hour plus parts so your looking at $300 unless you read, test, and repair it yourself and learn something new in the process. Something only you can do since you have the bike in front of you and all we can do is take blind stabs at the problem.
Old Sep 6, 2007 | 12:49 AM
<div class="FTQUOTE"><begin quote>Originally posted by: Snowprincess
dont be silly, its just a little sick and needs some tlc..</end quote></div>
hehe
But really though, somethings probably either shorted out, or theres a fuse thats out( not sure what fuses are on the Z even though i have one haha) or the fan is just locked up.
In other words i gots no idea. haha
Old Sep 6, 2007 | 12:51 AM
<div class="FTQUOTE"><begin quote>Originally posted by: CWO4GUNNER
get it very clean (pressure wash) let it dry out in the sun and get the shop manual and your multimeter out to do power checks to the fan motor and relay as you probubly have a short, blown fan fuse, or burned out fan motor. There is no guess work here you have to do the elec diagnostic checks and whether or not the fan is working and why is probubly one of the easiest. Otherwise you have to take it to the shop and the international rule for electrical problems is $100 minimum and $100 per hour plus parts so your looking at $300 unless you read, test, and repair it yourself and learn something new in the process. Something only you can do since you have the bike in front of you and all we can do is take blind stabs at the problem.</end quote></div>
Ugh. I was in this thread and made my post when you made yours. haha
But yea i agree.
Old Sep 8, 2007 | 09:50 PM
4TRAXIN's Avatar
check to make sure you have coolant in the radiator. If their is no fluid in the radiator the coolant temp sending unit will not read the temp of the fluid I crashed my vinson back in January, and it broke the lower bracket on the radiator and all fluid ran out
Old Mar 15, 2009 | 03:38 PM
quiksilva34's Avatar
CWO...just wondering where exactly the cooling fan fuse is? Reply back, PM me, or send an email to: matt.h.bloom@uconn.edu
Thanks a lot,
Matt
Old Mar 15, 2009 | 03:40 PM
Snowprincess,
Just wondering how everything panned out for you? I have a very similar problem where my quad is just running too high. The temp light is on and the radiator fan just doesn't kick on. I'm going to check the fan fuse and the sensor, but other than that im not too sure what else could be the problem. There is power running and it has coolant.
Any ideas?
Thanks,
Matt (matt.h.bloom@uconn)
