LT 185 starting procedure
Old Oct 1, 2007 | 09:45 PM
FJK's Avatar
FJK
Default LT 185 starting procedure
Just got an 84 from some people we know, that has not been used in a few years. Carb slide was stuck. So, I freed up the slide, took the carb apart, cleaned all passages, reassembled. Then, I drained the gas & refilled with fresh. Got it started yesterday & ran it around the back yard. Restarted it hot, ok. Now, today, I'm having trouble getting it started cold, approx. 65 deg F. So, I need some guidance for the correct startying procedure, beginning with the manual primer on left side of carb, choke pull out on dash, the other choke? on right side of carb, throttle setting (closed I assume), decomp lever (pulled before every rope pull), etc, etc. Any help would be much appreciated. Thanks, FJK
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
Wooodyii2
Jun 14, 2015 09:19 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
