'07 700 King Kaud
Old Oct 18, 2007 | 08:06 PM
arondrum's Avatar
Default '07 700 King Kaud
Has anyone had any problems with there bile not charging properly?
Old Oct 23, 2007 | 05:37 PM
MACHMASTER's Avatar
Had some issues with my 05 King Quad 700 not starting after sitting for a couple of weeks but added a battery tender and all fine now.
Old Oct 23, 2007 | 07:02 PM
arondrum's Avatar
That is what mine did also but no when lights are on it is showing only 13.45 volts at the peak and the min. Suzuki shows should only be 13.5 so I am below there normal at my peak. Any thing like that you have heard of?
Old Oct 24, 2007 | 01:25 PM
MACHMASTER's Avatar
I would check the battery. Completely charge the battery and check the output to see if you might have a weak cell in the battery, then check to make sure you don't have a constant draw on the system. Something might be putting a slow drain on the battery. Otherwise, pick up a battery tender for 30-50 bucks and see if that helps.
Old Oct 26, 2007 | 02:17 AM
HeftyLefty's Avatar
Arondrum, I as I understand your post, with your lights on you're getting 13.45 on a voltmeter with 13.50 being spec. Well 13.45 is only 5 tenths of a volt off spec.
What is your reading with your lights off?.
Old Oct 28, 2007 | 06:44 PM
KINGGREEN's Avatar
I have a 06 king quad and the battery has a slow draw. I asked my mechaic at st.onge recreation and he says that the efi has that one draw back. I have to charge it or boost if it sits more than a month . SOmeone said to turn the kill switch off when parked but that didn't change anything.
Old Oct 28, 2007 | 09:37 PM
HeftyLefty's Avatar
KingGreen, there is a new ecu from suzuki that cures this problem. Ask your dealer to check service bulletin #115.
Old Nov 2, 2007 | 09:00 PM
arondrum's Avatar
The voltage that was reading low was on a new battery. So now they have ordered me a new ECM that is suppose to fix the problem I will let you guys know if it works. Thanks for your help
Old Nov 8, 2007 | 11:53 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
was there bad ecu's in the suzs that are draining batteries or is that in the 07' models as well? my wheelers would set for 4 to 5 months and that would not be good.
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
jsmit116
Sep 18, 2015 10:34 PM
David Diaz
Sep 8, 2015 04:44 PM
DGNAZ
Sep 5, 2015 09:14 PM
