A Arms z400
Old Oct 31, 2007 | 07:28 PM
dopey393's Avatar
Default A Arms z400
Will a arms make the z400 lower if i got like +2 or should I go with a lowering kit. I heard the kits were bad for jumping so i dont think i want them. Im just looking for a way to lower the center of gravity cuz it seems to tip easy and it will handle better. z400s are really high.
Old Nov 2, 2007 | 04:32 AM
ss97's Avatar
Lets Ride!
Default A Arms z400
If you think a z400 is "tippy" I think perhaps you need to adjust your riding style.....
The only people I've seen call the z400 tippy are the ones that do not lean enough. They are light machines, and if you don't have your body in the correct position they will 2-wheel at higher speeds.
Going with +2 will make it wider, and thus change the center of gravity by default. You don't need to go lower unless you are racing flat-track.
Old Nov 2, 2007 | 08:21 AM
AIRMOBILE101's Avatar
Default A Arms z400
Tippy? I weight 135lbs max soaking wet and I had never had an issue with it tipping. Then again ,thats just me. Try putting smaller tires on it and adjusting your shocks.
NewGuy2481
Oct 6, 2015 05:54 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Canamaniac!
Sep 4, 2015 06:44 PM
