z400 question
Old Nov 3, 2007 | 05:16 PM
300exStroked's Avatar
Default z400 question
Posting about my buddies z400.. ya'll may know. He had a problem with the shim on top of the valve spring. Same valves and everything that came out of it but the stock shims that came in it wouldn't fit. Had to go to a smaller width shim. Anyone know what causes this or why it would happen? Not sure if any of you have experienced the same problem. Any information would help. Thanks.
Old Nov 4, 2007 | 05:08 AM
AIRMOBILE101's Avatar
Did you place the original shim back to its original valve/tappet/ keepers/bucket/ etc? You should have all the parts originally for that valve and that valve only(assuming you didn't intermix the valve parts) Did you by chance inter mix your intake shims with your exhaust? 285 intake/312-315 exhaust. You would have some issues if you did. Parts will start forming a custom fit over time. All valve train components must go back to their original location(intake or exhaust) with their original parts. Try swapping the shim with the other one. Good Luck!!!
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
