wife put 2 stroke fuel in the tank
Old Nov 21, 2007 | 05:00 PM
pucketts2001's Avatar
Default wife put 2 stroke fuel in the tank
The wife decided to ride my mid 90's 250 and it was out of gas and I wasn't home. She found a gas can that had some fuel in it and put a bit in. Turns out she put my chainsaw fuel in. She didn't put much in but it was running real rough. Instead of draining the tank (which I know I should have) I just filled it up the rest of way with gas (figured since it was just a little it would dilute it enough).
Anyhow, it is running a bit better now, but still bogs down real bad sometimes and will barely stay running and spit and sputter a bit before it will have enough power to take off again. Changed the plug, hasn't helped. Anyone got a good suggestion for the next step?
Old Nov 21, 2007 | 05:24 PM
ctateusa1's Avatar
I would run it a full tank through and see if it gets better.
Old Nov 21, 2007 | 05:42 PM
cataway's Avatar
first i would have to ask, how old was the gas ?
i have run mixed gas in the lawn mower ,it ran better had more power.
some day I'll try it in the quad on a dyno run ,just for kicks,i dar say no more than 50:1. cant say i know of any one thats done it.
tho i was told it lowers the octane, dont know if thats true ,nor do i know who to ask
Old Nov 21, 2007 | 05:59 PM
scootergptx's Avatar
Supersock
Hired Gun!
When the tank is ran through, change the plug and put in the regular gas.
Won't hurt it since it was a small amount. Worst it did was foul your plug.
the 2 cycle fuel was not old
Old Nov 21, 2007 | 06:02 PM
Something going on more than plug fouling. It runs great for a little while, then spits and sputters, no power, then catches up and runs fine again for a bit, then spits and sputters.
Old Nov 21, 2007 | 11:12 PM
Doctorturbo's Avatar
GOT BOOST!
Well.........hmmmmmm.
This is what I would do.
#1. Put another new plug in. (I've had DOA and bad plugs right out of the box)
#2 Drain the float bowl. The saw gas might have had water or trash in it.
#3 Run the P#ss out of it.
And yes, oil will lower the octane of the gas.
Old Nov 22, 2007 | 09:27 AM
LimpingLizard's Avatar
I always blame the wife when I screw up too.
Just kidding, do what Doctorturbo says, clean the carb, get fresh gas in there and run it. It'll be fine.
Old Nov 22, 2007 | 11:13 AM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: Doctorturbo
And yes, oil will lower the octane of the gas.</end quote></div>
#4 beat wife. [img]i/expressions/face-icon-small-wink.gif[/img]
#1 has happen to me before.
Old Nov 24, 2007 | 06:57 AM
MIDDLEAGEDCRAZY's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: LimpingLizard
Just kidding, do what Doctorturbo says, clean the carb, get fresh gas in there and run it. It'll be fine.</end quote></div>
I so wanted to say that, But decided to let it go. I would have drained the gas, cleaned the carb, and changed the plug. Don't figure it to do much harm. Just needs to be flushed out.
