86 Suzuki250R
Old Dec 3, 2007 | 07:07 PM
sandshark33's Avatar
Default 86 Suzuki250R
Hi, I am new on here. I just bought a 1986 LT250r and noticed it hard to kick over. It sounds like its starving for gas. Does anyone know what problems these bikes have. I am familiar with Yamaha Banshees and dont know to much about these 250's. Any general basic problems and fixes would be appreciated.
Old Dec 3, 2007 | 11:14 PM
Scooter86's Avatar
Knows Old ATV Questions!
Is it physically hard to kick, or just hard to start? They do tend to kick a tiny bit harder than a Banshee, as you have 249cc under compression vs 175cc for the Bansh. My '85 always likes just a bit of throttle when starting. Actually, I usually give her a few sissy kicks, get it to TDC and then kick it over good with about 1/8th throttle dialed in and choke on. This usually lights the fire when the engine is cold. Once warmed up, mine starts first kick, no choke. Otherwise, they are a lot like the Banshee, only half the carbs and cylinders to monkey with.
Old Dec 4, 2007 | 01:18 PM
It seems if I have to have my choke on and give it 5 fast short kicks and one hard one with the throttle more than halfway to get it started when cold. I think it may be the carb. Have you heard of any carb problems.
Old Dec 4, 2007 | 01:31 PM
Scooter86's Avatar
No, I haven't. On the other hand, the quad is 20+ years old, it could probably use a good cleaning. The other thing is that I have always had to jet for the season with mine. Check your plug, is the tip white or lighter in color? From summer to winter here in NY I have to go up one size on the pilot and about 3 or 4 on the main. Sorry, I can't give you the numbers I have been running, as I have started putting my quads up for the winter to persue other interests. All in all though, it doesn't sound like it is starting that bad from what you wrote. I bet it is just a touch lean.
Old Dec 4, 2007 | 05:19 PM
Thanks alot for your help.
