fcr carb
Old Feb 22, 2008 | 08:14 PM
nimbh2's Avatar
Default fcr carb
how do you what millimeter youre carb is?
you measure the opening right?
Old Feb 23, 2008 | 01:51 AM
JustRandy's Avatar
Default fcr carb
You measure the diameter of the hole nearest to the slide. Sometimes the holes on the outside are much bigger.
Old Feb 23, 2008 | 02:46 PM
nimbh2's Avatar
Default fcr carb
i knew you would have the answer you always seem to lol
Old Feb 23, 2008 | 03:20 PM
nimbh2's Avatar
Default fcr carb
hell its a 41 mm is that to big. am i gonna lose any of the lowend grunt?
Old Feb 23, 2008 | 03:24 PM
JustRandy's Avatar
Default fcr carb
That's the goal! [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Feb 23, 2008 | 03:25 PM
JustRandy's Avatar
Default fcr carb
<div class="FTQUOTE"><begin quote>Originally posted by: nimbh2
hell its a 41 mm is that to big. am i gonna lose any of the lowend grunt?</end quote></div>
What's a 41mm???
Old Feb 23, 2008 | 03:34 PM
nimbh2's Avatar
Default fcr carb
41mm fcr carb
Old Feb 23, 2008 | 03:36 PM
JustRandy's Avatar
Default fcr carb
Air travels faster thru a smaller hole. When you're at low rpms, you need the air to be traveling fast to fill the cylinder well enough for the lowend grunt. If the carb is too big, you could see a drop in lowend. But if the carb is too small, you'll see a drop in topend. So, looks like the carb size just pushes the HP curve around the rpm band.
Old Feb 23, 2008 | 03:37 PM
nimbh2's Avatar
Default fcr carb
if does couldnt i just put a 13 tooth sprocket to make up for it
Old Feb 23, 2008 | 03:46 PM
JustRandy's Avatar
Default fcr carb
41mm fcr carb</end quote></div>
Huh... Didn't know they had 41's in the fcr.
Sizing carbs for small engines is a guessing game. If we're talking about a z400 that came with the 36mm and you're planning to use a 41mm with no porting or cam changes... I think that may be a bit on the big side. Especially if your using a foam filter (slows the air down).
