how bad is it to run without the stock baffle in an 03 z400 exhaust
Old Apr 5, 2008 | 02:47 PM
drag101's Avatar
Default how bad is it to run without the stock baffle in an 03 z400 exhaust
well my baffle on my 03 z400 fell out and i was wondering how bad it would be to run without it for a little while till i can afford a new exhaust? because i kinda like the way it souinds now and dont wanna put it back in
Old Apr 5, 2008 | 07:21 PM
mikem92's Avatar
I know that some people take it out on purpose. Ive done it on a little yamaha i had. It shouldn't really be too bad for it, although if you want the extra power from taking it off, jetting is probably a good idea. The only thing that it may be bad for that i can think of is your valves or your neighbor's ears. I was just told about the valve thing before but i dont know if it is true or not. I rode my lt230s without a sparkarrestor for some time and havent noticed any damage. however, i do have an exhaust with it back in now.
Hope i could help
-mike
Old Apr 6, 2008 | 09:52 PM
JustRandy's Avatar
I guess there is a chance you could start a fire. That's what they say anyway..... Other than that, the spark plug may be a little on the sooty side and may foul on you. Probably will lose some power as it gets hotter due to running rich.
Old Apr 7, 2008 | 07:21 PM
crazy1291's Avatar
what does it do to the valves? Burn them up or something due to lack of backpressure? I wouldn't believe that though if you rejet- it just doesn't make sense to me atm.
Old Apr 7, 2008 | 07:44 PM
JustRandy's Avatar
http://autos.yahoo.com/maintai.../engine/ques053_1.html
I've heard lots of old timers talk about burning your valves if you remove a muffler or something. I haven't been around long enough and worked on enough engines to really pin down a cause for it, although I see burned valves all the time. I'd have to agree with the article though... The hotter the engine, the more likely you will burn a valve.
Old Apr 9, 2008 | 10:04 PM
crazy1291's Avatar
but if you rejet, then the engine won't run hot so you should be fine. How come you don't hear about everyone who has an aftermarket pipe with burned valves? it's because they rejeted/reprogrammed efi.
Old Apr 9, 2008 | 11:32 PM
JustRandy's Avatar
True...
Old Apr 9, 2008 | 11:33 PM
speedyman12345's Avatar
haha lack of back preasure, good guess but no, the less back preasure the better on a 4-stroke, if you take the baffle out you will need to get higher because of the better airflow, but possibly not
Old Apr 10, 2008 | 01:01 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
you do not need any back pressure at all, you just need to control the speed at which the exhaust shoots out the pipe.......
Old Apr 10, 2008 | 07:51 PM
JustRandy's Avatar
Actually, you want negative backpressure. Backsuction if you will. This is why you cannot run no pipe at all. You might think that no pipe would give the least amount of backpressure, and at first thought that sounds about right. But actually, the escaping gases are traveling so fast inside a pipe that they have a negative pressure (suction) behind them that sucks even more gas into the combustion chamber during valve overlap. Having no pipe elimnates this effect and is probably the highest amount of backpressure you can have without actually sticking a banana in the pipe.
