Starting a Z400
Old Apr 16, 2008 | 11:57 PM
RealAceRider's Avatar
Default Starting a Z400
How do you override the saftey feature on the z400 that makes you pull on the clutch to start it. Because i bought a new clutch perch and lever and there is no spot for the safety plug in to go. Could you by chance take the wires and ground them to the frame?
Old Apr 17, 2008 | 11:02 AM
warrior226's Avatar
I cant remember if the switch is "normally open" or "normally closed"
I replaced my clutch perch last year, and I'm thinking that the 2 wires going into the plug are wired together, if not they're kept separate. You don't have to ground anything to the frame.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
garyt1975
Jun 5, 2015 08:53 AM
Zee400
May 31, 2015 12:48 PM
1000gade
May 27, 2015 12:37 PM
