Found a use for the decompression lever
Old May 7, 2008 | 01:02 AM
ryankopecki's Avatar
Default Found a use for the decompression lever
So I found another use for a decompression lever. Say a river you cross regularly decides to change as rivers have the habit of doing, and it gets deeper. Your intake may get a little water in it causing a hydro-lock condition. Just move the vehicle to shallower water, pull the lever and the hydro-lock condition is eliminated. A couple kicks and a few more and you're back to running.
Also, the back end of a lt230s will float with the tops of the tires (22x11s) still out of the water as long as no fat *** is sitting on it. With a little more flotation placed in some dead space in the front you should be able to float it across streams and such.
ylomnstr
Sep 22, 2015 12:19 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
lancemll88
Sep 6, 2015 03:03 AM
