1985 230s quadsport rear brake light
Old May 26, 2008 | 09:50 PM
tomkat510's Avatar
Default 1985 230s quadsport rear brake light
the other day i put a new bulb in but doesnt want to light, when i got the bike it didnt work so i bought a bulb, does any of the wire from the front light have anything to do with the brake light???
Old May 26, 2008 | 11:59 PM
JustRandy's Avatar
Its just a taillight, not a brake light. It gets power from the grey wire when you turn the lights on. The black wire is ground. The power is AC, not DC. I don't know if it makes a difference what bulb you use. That might be something to look into. You can't exceed 45-50 watts total for the lighting system or you'll burn up your lighting coil.
Old May 31, 2008 | 05:55 PM
Rocan's Avatar
This makes me wonder... any way to turn it into a Brake light?
Old May 31, 2008 | 06:31 PM
JustRandy's Avatar
I'm sure there is a way.
Old Jun 1, 2008 | 08:23 AM
Rocan's Avatar
Hmmm... Was looking at how my dads Rear brake light is set up on his Honda Shadow... Looks pretty simple- just a little switch like thing that gets pressed with the application of the brakes
Old Jun 1, 2008 | 08:37 AM
BigMc's Avatar
BigMc
That would be a simple upgrade. A simple contact switch on the rear brake peadel would work great. Or, in the intrest of longevity in the muck, a magnetic switch on the rear master cylinder plunger rod.
Good upgrade idea.
Old Jun 1, 2008 | 08:56 AM
BigMc's Avatar
BigMc
To do that the socket would need to be modified or replaced. It would require a dual filament bulb from a newer machine. One filament for each tail and break light. And (as JR has mentioned) the total wattage would need to be kept to a minnimum. I think the stock 230 bulb is only rated at 5 or 10 watts. It will not be very bright. But could use LED's I guess.
Wow. One page. Aint it cute JR? [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 1, 2008 | 09:38 AM
JustRandy's Avatar
Or just use the one bulb as a brake light with no tail light.
It all starts with one. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 1, 2008 | 04:28 PM
BigMc's Avatar
BigMc
(1) That would work. And.
(2) A...MEN!!!!!!!!!!
<div class="FTQUOTE"><begin quote>Originally posted by: JustRandy
It all starts with one. [img][/img]</end quote></div>
Old Jun 1, 2008 | 07:27 PM
tomkat510's Avatar
my main ? is do the wires come from the head light set up, and run to the tail light? is there a rely somewhere??
