Eiger U-Joint going into motor
Old Jun 20, 2008 | 12:10 PM
Phil05Eiger4x4's Avatar
Default Eiger U-Joint going into motor
The Ujoint i believe it is where it goes into the motor in front where the driveshaft comes out is leaking oil and its got even worse im not sure what kind of tools ill be needing and if its a bi*** to do . i guess theres a bearing in there a seal and a shim or something the dealer is telling me so if you guys could throw anything my way appreciate it lots
thanks again
phil
Old Jun 22, 2008 | 09:32 PM
rolsmojave3's Avatar
Look at a parts diagram and see if the shaft will pull out or not. To get the seal out you'll probley end up cutting it apart, if it wont' pull out with a pick or screwdriver. You'll have to have something to install the seal too, a seal installer or a socket the is the same size as the outside of the seal.
Old Jun 25, 2008 | 05:03 PM
i just noticed also that now the rear is leaking coming out the back of motor is it possibly both going bad at same time? or is one causeing the other to leak somehow??????
Old Jun 25, 2008 | 06:00 PM
would any of that stop leak for the motor oil work? or damage/hurt anything???
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
