Another stupid question
Old Jan 24, 2001 | 04:02 PM
Paintballer's Avatar
I went to check the clutch oil level in my 87 LT250 and realized there is no level indicator plug or site glass or anything. How do you know how much to add? The Clymer manual is worthless here. I am trying to determine if I am leaking oil into the crankcase, and if I can't keep an eye on the level..how do I do that?
Old Jan 24, 2001 | 05:56 PM
CALDS650's Avatar
I cannot say on the LT250 but on my LT500R. There is a screw on the clutch side that you remove. When you add oil you fill till it stats to drip out then stop. Hope this helps.
Old Jan 24, 2001 | 06:37 PM
juggalo's Avatar
on my 85 there is a little hex bolt that you unscrew. its on the clutch side and its right above one of the screws on the bottom of the case. hope that helps you out.
Old Jan 24, 2001 | 07:47 PM
The 85&86 have that plug to check the oil level, but the 87 doesn't. Clymers doesn't give a clue on it either
Old Jan 26, 2001 | 01:49 AM
anyone? pretty please?
Old Jan 26, 2001 | 08:48 PM
DannoLT250R's Avatar
I hope this will help. I have an old Clymer for the 85's through 88's and all they say in the old book is that the the refill capacity is approximately 1.9 US pt (900cc), and there is no check bolt like the 85's & 86's. The only way I would know to check to see if you are loosing oil is to drain the oil into a measuring cup and see if you get out what you put in.
Danno
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
