1987 lt250r ?'s
Old Jun 22, 2008 | 11:23 PM
SteelCorso's Avatar
Default 1987 lt250r ?'s
well its come time to rebuild my 87 lt250r and i had a few quetions.
ive got my new Wiseco piston kit (.060 bore) i lost two bores due to wrist pin gauging, and my headwork will be done tomorrow.
my questions were..
-does anyone know what a good upgrade from a stock reed cage would be.. due to the fact that the 87 is only a 5 bolt cage and v-force doesnt make anything for it.
-also im looking for a little more low end torque.. any suggestions on sprocket size? or jet size?
Old Jun 23, 2008 | 11:29 PM
theCATman's Avatar
Boyesen reeds OR a Rad Valve...... if Boyesen offers one.
Drop one tooth on the front sprocket. But, remember this also requires more chain. So, if you are already about maxed out on chain stretch, you may need a new chain to go with the sprocket change.
You could also take a link out, but that's a band-aid fix on a bullet wound if the chain is already worn out.
Old Jun 25, 2008 | 01:00 PM
Suzuki Rider's Avatar
Yea drop on tooth in the front add one to the rear. And try google for some VF2's for the intake. You might can find a used set and replacement petals are still out there too.
GL
Old Jun 28, 2008 | 04:19 PM
SteelCorso's Avatar
ok so im over halfway done with the break-in due to a busy schedual.. i did infact find a billet aluminum 12 pedal v-force reed cage custom built by Tudors Performance. and i am due for a new chain so i might as well set it up right. thanks for your help guys.
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
Steeldon
Sep 8, 2015 10:51 AM
