LT250R Specs
Old Aug 24, 2008 | 09:45 PM
mud skipper's Avatar
Default LT250R Specs
I took a 91 swing arm on an old frame i had got just for it and it went right on my 85...
Old Aug 24, 2008 | 10:28 PM
Kodiaks_only_LT250R's Avatar
Sweet, thanks
Old Aug 26, 2008 | 10:13 AM
hey lt230sman, did you get the 250r? how's it working out, etc..
Old Aug 18, 2009 | 12:37 PM
twhah's Avatar
Hey yea on my 86 there are two thrush washers on either side of the wrist pin bearing. Just had One break! (not good). LOL
Old Jun 8, 2011 | 06:10 PM
  #15
lt250rrider1988's Avatar
Default 250r problem
lets say i just got an lt.alright its running ruff.idle's fine.but when you start to take off.its constant bog unless you feather the clutch.it wasnt running until about 2 days ago.carb needed cleaning.what do you guys think the problem is?
Old Sep 16, 2011 | 11:56 PM
  #16
skyline-01's Avatar
hello , i have a 85 quadracer with a lt250r i bored it .60 over put a new forged wisco piston in it and now it dont get over 6k rpms can anyone help me with it , it acts like as soon as the power ban comes in the rev lamiter comes in i have tryed everything i no to do
Old Sep 7, 2012 | 01:32 PM
  #17
2stroke King's Avatar
Exclamation 1986 Suzuki LT250R
I've got the 1986 model and I've been running it for about 10 years now. Here is a basic list of things to watch out for:
1. Chain tension. The 85-86 models use an oval style chain tension system around the rear axle. If you jump or ride the bike rough, it's easy to pop the chain off.
2. Clutch spindle. The clutch spindle connecting the clutch cable to the clutch basket assembly is not secured. There is no bolt to hold that in like the later models. If you pull that out too far, your clutch will disengage.
3. AIR LEAKS! The 85-86 models are prone to air leaks on the stator cover, intake port, and exhaust port. This is the most common cause of engine seizure.
4. Don't run out of gas! Running the 85-86 models out of gas completely is a very bad idea. As the LT250R is a premix model, running it out of gas quickly dries out your piston and cylinder. This is the 2nd most common cause of piston seizure.
Wiring diagrams are available on google images. Everything else is pretty simple. Sorry to hear about the thrust washers! I know those are a pain.
Old Sep 7, 2012 | 01:34 PM
  #18
Exclamation Skyline is about to seize his brand new piston!
You'r engine is about to seize, back off the throttle, up your oil/gas ratio, and shoot some WD40 in the spark plug hole before it's too late! Sounds like you didn't follow the "Break IN" period instructions.
Old Sep 7, 2012 | 01:37 PM
  #19
Your main jet is clogged, the bike isn't getting enough air, or you're losing compression.
Levi Enstad
Sep 26, 2015 08:00 AM
raman8tor
Sep 20, 2015 07:35 AM
Halffast17
Sep 11, 2015 02:30 PM
