swing arm issues
Old Sep 13, 2008 | 12:30 PM
cameojon's Avatar
Default swing arm issues
New to the site!! great place!! here is my first post!! thanks for any and all help.
Ok I bought my lt250R off ebay and pretty sure I got screwed, been fixing small things like carb issues and a water pump that came apart, but the new thing is a cracked sway arm right where the bearings are. Now this is a 86 frame with a 87 motor. I have seen some 87-up frames and I really like the sway arms on those years, so can I put an 87-up arm on my 86 frame? or would I just be better off in the long run finding a 85-86 arm and bolting it on. I was a machinist for 5 years, and a mechanic for 7 years now so if I have to do some modifying its not a problem but if i have to do a lot of work and I get done and this thing takes another crap I may just have to sell it then I'll be out what work I did get done (I really wish I didn't buy this thing)
Old Sep 13, 2008 | 03:21 PM
cameojon's Avatar
found a swing arm on e-bay but its off a lt500 quadzilla would this work? and its at $100 no bids plus no axles or bearings
Old Sep 13, 2008 | 04:11 PM
270quadsportguy's Avatar
why not just have it welded and call it good. probably better than buying something off line and it being crap also. Id amagine u have the circle swingarm where u turn the carrier too adjust chain.
Old Sep 13, 2008 | 06:36 PM
cameojon's Avatar
yep, circle swingarm. that is a good idea, maybe weld it then dial it in on a CNC mill and cut out the area for the centric, I'm going to go ahead and tear it apart and see what I have. thanks
Old Sep 20, 2008 | 08:36 AM
mud skipper's Avatar
Yeah a swing arm off the newer 250 like 88,89,91 will fit ya bike. I would change it out if u can cuz they are better then the kind u have on it now..As for the 500 Im not sure on..
Old Sep 21, 2008 | 01:27 PM
cameojon's Avatar
cool, thanks for the info. I think I'll just go that way. I found more stress cracks on the sway arm so if I try to fix it I think it just might get worse
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Jul 28, 2015 12:12 PM
Bell21
Jul 28, 2015 06:52 AM
Unzzy66
Jul 11, 2015 10:01 PM
