water in exhaust
Old Oct 6, 2008 | 05:32 PM
bman1981's Avatar
Default water in exhaust
i have a problem with my suzuki vision 500.I went thru a pond and water got in the muffler so i pulled the plug and tipped it on end, pulled it over till water quit cuming out. now it will idle but i can't give it any gas or it will start popin and die?????
Old Oct 7, 2008 | 10:39 PM
daniel450's Avatar
you should remove the entire exhaust and let all of the water drain out. Next check to see if you have water in the airfilter box if so dry it out and then give it a try.
Old Oct 8, 2008 | 12:03 AM
thewolverine450's Avatar
You also need to check you oil you probably have milky oil now. That is an easy path for water to get into the motor.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
bvolks
Sep 13, 2015 12:57 PM
Bigtwin700
Sep 9, 2015 09:32 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
