Cold Weather
Old Nov 21, 2008 | 04:55 PM
CrazyDLT4's Avatar
Default Cold Weather
Why is my Z400 so hard to start in the cold weather?
Old Nov 21, 2008 | 06:40 PM
atvman29's Avatar
most vehicles are a little tougher to start in the cold. try turning the choke all the way on for when you're starting, once its started you should be able to turn it back to half, then once its warm, you can turn the choke back to off.
if you had a new '09 Z400 it would have EFI and start on a dime everytime no matter what temp.
Old Nov 22, 2008 | 02:22 PM
CrazyDLT4's Avatar
well i wish i had a 09... it is an 06 and i have tried the choke thing, still really hard. as soon as i shoot it with some starting fluid it fires right up... think it might have other problems than just the cold????
Old Nov 22, 2008 | 02:29 PM
atvman29's Avatar
its always a possibility, how cold is it where you are?
Old Nov 23, 2008 | 02:38 AM
Simsie147's Avatar
not true atvman29, i have a 2008 suzuki ltr-450 and it is fuel injected and starts hard in the cold, especially when its under 30 or 40 degrees
Old Nov 23, 2008 | 05:35 AM
the_journalist's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Simsie147
not true atvman29, i have a 2008 suzuki ltr-450 and it is fuel injected and starts hard in the cold, especially when its under 30 or 40 degrees</end quote></div>
I started my LTR this morning when it was still 27 degrees. Fired right up without so much as a hiccup.
The wife's Ozark 250, on the other hand, was nearly impossible to get fired up. Had to wind on it forever with the choke on. Then, had to baby it long enough to warm the engine a little before it would even move out of its tracks.
What mods does your LTR have? A good portion of engine mods that make more power will cause an LTR450 to be harder to start in the cold.
Old Nov 23, 2008 | 01:26 PM
atvman29's Avatar
Well then you might have something wrong because that's one of the big benefits of efi. Temperature should have little effect on starting.
Old Nov 24, 2008 | 10:19 AM
ss97's Avatar
Lets Ride!
z400's are notoriously warm blooded...... as long as it is not taking too long with the choke on it is normal for the most part......
Old Nov 24, 2008 | 04:03 PM
CrazyDLT4's Avatar
thats what i have heard from a couple people that they are warm blooded.. it takes a bit to start but once its started runs great.. im in southern ohio and in the night it gets down to the 20s sometimes. i was just making sure i had no major problems. thanks guys
ultangler
Nov 30, 2024 01:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
