1990 250 Help
Old Dec 18, 2008 | 12:41 PM
Bonerable's Avatar
Default 1990 250 Help
Hi, I'm new on here looking for a little help for my quad. It has a mikuni carb model L/M/N/P/R/S/T. When you run it all out, it runs fine. Once it gets hot if you putt around about half throttle, or it you just ride slow and easy, it will shut down and the plug will be wet and fouled. I took the carb apart and cleaned it out and installed a new needle and seat. Now, it is doing the same thing. If anyone has any ideas, let me know.
Thanks
Old Dec 18, 2008 | 04:11 PM
JustRandy's Avatar
Did you try a new spark plug? D7EA.
Old Dec 18, 2008 | 08:28 PM
Bonerable's Avatar
Yes, I had a D7EA and also went up one to a D8EA
Old Dec 18, 2008 | 11:48 PM
JustRandy's Avatar
Did you just get the quad? What's the history behind it?
How's the air filter? Is there any reason to believe its jetted wrong? I mean, did it run fine one day and then start this?
The carb is obviously not dirty or the plug wouldn't be wet and black.
JustRandy's Avatar
Oh, stay with the D7EA. The 8 is a colder plug.
Old Dec 19, 2008 | 09:00 AM
Bonerable's Avatar
The quad is actually my neighbors. He has had it since it was new and has been struggling with this problem for years.
Old Dec 19, 2008 | 12:47 PM
JustRandy's Avatar
Did you try moving the needle clip around? I'd move the clip higher on the needle and that will restrict some gas at half throttle. That will probably solve your problem.
Old Dec 19, 2008 | 01:27 PM
Bonerable's Avatar
I'm glad you said that because that is what I was going to try this weekend. Do you think I should just go up one notch?
Old Dec 19, 2008 | 01:43 PM
JustRandy's Avatar
I think you should try all notches until it runs right. You should also inspect the needle for any wear. If it has significant wear, you really should replace the needle and the needle-jet.
I'm guessing you have the 1990 250S quadsport? If so, the correct needle is 5HN31 and the stock clip position is in the middle. The correct needle-jet is O-3.
Over time, the needle vibrates against the hole and wears the needle and hole.... And that lets too much gas thru.
If you can't find that needle, the mikuni 5L1 is the same thing.
This might be of use to you: http://www.alpha-sports.com/satv/1990/LT250S/04.htm
Old Dec 19, 2008 | 02:30 PM
Bonerable's Avatar
I really appreciate the help!
