03 z400 help
Old Dec 24, 2008 | 09:01 PM
afowler8806's Avatar
Default 03 z400 help
i have a little wobble comin from my right rear tire and i switched the tires around and its still comin from the right side. i dont kno where and what to check next. any help or suggestions would be nice.
Old Dec 24, 2008 | 11:55 PM
Doctorturbo's Avatar
GOT BOOST!
Jack it up and take the wheel off. Start it up and put it in first gear and look at the axel flange from the back. See how much wobble you get on the face of the axel.
This will tell you if you have a bent axel.
Old Dec 25, 2008 | 01:04 AM
cherokee99's Avatar
in some cases it could be just bearings in the axle. the wobble will be more prevelent on the right side since the left side has the chain tentioning it. thats a possibility, provided the axle is not bent
Old Dec 25, 2008 | 07:08 PM
cataway's Avatar
its an 03 ,yeah i will all most guaranty its the bearings ,when you get it apart your going to find that the bearings only have a seal on the out side ,all the grease gets squeezed out and any water that gets in turns every thing to rust, the frount ones are the same ,sounds like a good time to do them as well.
Old Dec 26, 2008 | 02:51 AM
could it just be the hub on the right side and not the whole axle?
Old Dec 26, 2008 | 06:54 AM
cataway's Avatar
any thing is possible ,
i did bend a rim after having a miner altercation with a tree a few years back ,is that the kind of wobble your talking about?
could you of bent just a hub ,sure you could , could you have a bent Axel ,sure you could . you may also note all of it is on your end of this .
Old Dec 29, 2008 | 06:45 PM
i have replaced the axle and the rim and the wobble is gone.
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
