92 quadrunner won't run when warmed up
I have a 92 Suzuki quadrunner 4WD that starts and runs great, until it is warmed up. Then it dies and won't start until it cools down. I am looking for some ideas on what the problem could be. I don't know if it's carburetor or electrical.
Thanks for your help
most likely you are chokeing it to warm up? your pilot/slow jet is clogged and your unknowingly using the chke as the idol circit, so when its warn you turn off the choke and it dies. a good carb cleaning wont hurt anything and can eliminate that problem
good luck
good luck
IMLN
Sep 28, 2015 03:32 PM
Sep 1, 2015 11:59 PM
