KFX 400 trouble with the reverse
Old Feb 9, 2009 | 12:26 AM
moepower09's Avatar
Default KFX 400 trouble with the reverse
I have a 04 Kfx 400 and my reverse works but not like it was two days ago foward is fine but seems to not be pulling and im not sure why.
Old Feb 9, 2009 | 08:22 AM
ss97's Avatar
Lets Ride!
Does it go backwards at all? Could be the rev limiter on the reverse....
Old Feb 9, 2009 | 06:07 PM
moepower09's Avatar
yes but it seems to not pull hard and engine just rev up
Old Feb 9, 2009 | 06:08 PM
moepower09's Avatar
Old Feb 10, 2009 | 07:38 AM
ss97's Avatar
Lets Ride!
Well there is a rev limiter on reverse, it is really not supposed to pull very hard......
Is it just the limiter? Or is the clutch slipping? Try adjusting the clutch pull and see if that makes a difference.
Old Feb 10, 2009 | 09:13 PM
moepower09's Avatar
thanks for the Info. I also have a suzuki ltz250 and I was wondering how do you adjust the front brakes because they are to ferm and my wife has rolled it over because of it to ferm.
Old Feb 11, 2009 | 12:15 PM
ss97's Avatar
Lets Ride!
Brakes are too firm? Not sure how to fix that one, most people like them firm. Usually a firm lever and good stop is a sign of good brakes.
If she is rolling it over because of good brakes there is a problem with her riding technique...... Either she is not using the back brake enough, or she has poor body position while braking. If she's not leaning back while braking hard it will result in a problem. Perhaps she just needs to practice some techniques for better control, or use the back brake more.
If she is in any situation where front brakes might cause a roll-over, she needs to be leaning way back, riding the rear brake, and "fanning" the front brake so as not to lock them up.......
But if you adjust your brakes to the point where they won't lock up, you might suffer during regular braking. There might be too much fade in the brakes and when you need to stop really fast it might not be there........ IMO your brakes can never be too good......
Old Feb 11, 2009 | 12:20 PM
ss97's Avatar
Lets Ride!
double post
ss97's Avatar
Lets Ride!
Brakes are too firm? Not sure how to fix that one, most people like them firm. Usually a firm level and good stop is a sign of good brakes.
If she is rolling it over because of good brakes there is another problem, with her riding technique...... Either she is not using the back brake enough, or she has poor body position while braking. If she's not leaning back while braking hard it will result in a problem. Perhaps she just needs to practice some techniques for better control, or use the back brake more.
Old Feb 11, 2009 | 12:22 PM
ss97's Avatar
Lets Ride!
triple double.......this forum is going south fast....
