LT250R A-Arms
Old May 18, 2009 | 07:13 PM
lt230sman's Avatar
Default LT250R A-Arms
Alright, Ive got an 86 LT250r with the doofy camber and narrower-than-preffered width up front.
My question is, can I get any more width and corrected camber from later year (87-92) arms? I know I'll have to cut down the bearings a little bit, but thats a nonissue for me. Otherwise, everything should bolt up, right?
Old May 19, 2009 | 08:46 PM
LordZilla87's Avatar
'87 and up a-arms don't fit '85&'86 frames! The frame mounts are totally different.
Old May 19, 2009 | 10:08 PM
lt230sman's Avatar
im aware of that; "I know I'll have to cut down the bearings a little bit, but thats a nonissue for me"
the bearings on the later model arms are longer and have external seals, while the older ones are shorter and have internal seals. they are both the same diameter and the newer ones can be cut down to fit the frame tabs without a problem.
lt230sman's Avatar
what i wanna know is - are the later model arms any wider? and will they have more negative camber?
Old May 20, 2009 | 08:48 PM
NewportHillClimber's Avatar
the mounts on the newer machines wont work at all. unless you cut the arms in half and weld them narrower. youd have to do way more than just grind the mounts down
Old May 21, 2009 | 12:30 AM
Spencer2829's Avatar
so i think what he is saying is he is not worried about the mounts... does anyone have 87-92 a arms they could measure for this man?
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
XxS0ccerstarxX
Aug 31, 2015 04:47 AM
XxS0ccerstarxX
Aug 27, 2015 07:40 AM
musselmark
Jul 17, 2015 02:40 PM
