suzukiquadrunner
Old May 27, 2009 | 07:48 AM
butch08's Avatar
Default suzukiquadrunner
how do i bleed front brakes
Old May 27, 2009 | 08:01 PM
biguns's Avatar
if there discs, its the same as any brake set up, just pump the brakes then crack the bleeder while squeezing the brake lever until nothing but fluid shoots out..the bleeder or nipple is usually a 3/8 size
Old May 27, 2009 | 09:29 PM
86qscamo's Avatar
it takes forever sometimes also if it has set for a long time you should take the lines apart and blow with compressed air . i had a clog on the left side line on both of my quadrunners that i restored
